Hi folks, this forum seems to be a great resource to get questions answered, so I am posting here in the hope that someone can help me.
I have a superdish and used to get the 119 and 121 satellite signals (but no 110 which I don't really need) at my old place. Now that I moved I find that I am getting only 110 and 119 at my new place (same zip code 98006, just 1 mile from my old place). I have the dish mounted on a small tripod-like thing inside my apartment facing a large window that faces south. My condo association prohibits placing the dish anywhere outside, including the outside walls of the unit, and my patio faces the north so I don't get a signal there. I have tried talking to the condo association multiple times to permit me to install the dish out on the lawn in front of the house (that faces the south) but to no avail. So the only choice left for me was to have the dish inside my home near a window.
I have the elevation and skew for the dish set to the values shown in the point dish screen in the receiver. However, no matter how much I try, I am not able to get the 121 satellite (I can get both 110 and 119 though, but the international programming I want is on 121). The 121 point dish screen shows a signal strength of around 70 but in red with "Wrong Sat - EchoStar 119 West)". I tried various transponder settings like 11, 15 and 21 but it still says wrong satellite. At first I thought it must be a problem with the FSS LNB and so had it replaced with another working LNB, but still have the same issue. I have the following questions:
1) If the dish is set up so that I get both 110 and 119 with good signal strength ( > 75), is it correct to assume that I should be also getting 121 without repointing the dish ?
2) For the "Wrong Sat" message, does it really mean that the FSS LNB is working but picking up the wrong sat ? If so, could it be fixed by making small adjustments to the azimuth or elevation of the dish ? I have tried that but didn't succeed.
3) I have checked all the cables, the DP34 switch connections etc and they seem to be fine. Also, my window is completely open so there is no chance of attenuation through the window glass or something. Since I am getting both 110 and 119 with good strength, what else could be the technical reason for not getting 121 ? There are some tree branches in the distance but I can't tell if they are in the line of sight. Could it be simply that since FSS is lower power signal it is getting attenuated by those tree branches ?
4) Lastly, what are my legal options to convince the condo association that I am not able to get a signal inside the unit, and so need to place the dish outside ? I have a technician come by who told me that if I place the dish outside I will definitely get the 121.
