Just received U525 boot strap 1012. I don't see any visual changes yet.
Sent from my SM-G920P using the SatelliteGuys app!
OK, thanks.Should be no changes, I believe the only thing that changed that you will notice is the standby screen.
And it broke Alexa and the Voice Function on the remote. I made a separate post about this.Should be no changes, I believe the only thing that changed that you will notice is the standby screen.
You are right. I just checked mine and voice commands show up on the screen, but nothing happens.And it broke Alexa and the Voice Function on the remote. I made a separate post about this.
J Sheridan has reported that voice commands using the 54 remote and Alexa voice commands are both working on his Hopper3 running U525. Can others that have upgraded to U525 test voice commands?
Yeah, I checked again before I went to bed, and the remote worked fine. Very odd
Does your 54.0 remote control voice commands work?My Hopper 3 still says U522 is the latest for it.
My 54.0 remote control voice commands also no longer work on both my H3s and 4KJs with U525.Based on the previous responses I manually updated both of my Hopper3 receivers to U525 software. Like others I have lost the ability for either receiver to respond to voice commands from the 54 remote or Alexa commands. The 54 voice commands display on the TV but the hopper3 does not execute. The Hopper3 is connected to the internet and Dish Anywhere works with both receivers. I also reset both Hopper3 receivers but that did not fix it. I will now wait and see if it gets fixed after a while. It doesn’t make sense but perhaps it takes some time for Dish to communicate with the updated receiver.
YesDoes your 54.0 remote control voice commands work?
It appears the U525 has broken the 54.0 voice command since yours still work on U522.
