jself1982,
From what I see your hardware meets all the requirements...
Ok I want to verify if you installed the software correctly...
2.2 Software Installation
Before You Begin
Make sure that the TWINHAN TV product is actually installed (for more information,
please refer to Hardware Installation in the previous section).
Turn on your computer
Driver Installation
Step1: Cancel "New Hardware Wizard"
After the computer is turned on, Windows will find New Hardware. Please choose "Cancel" from the pop up windows. We will install the driver later by the TWINHAN TV installation program automatically.
The above step is important you must not allow windows hardware wizard to install anything, you want to
manually install the drivers…
... (pictures)
Step2: Activate TWINHAN TV CD-ROM
Insert the TWINHAN TV driver CD into your CD-ROM drive, the "Autorun"window should appear. Click on "Install Software and Driver". If the "Autorun"window does not appear, please open the "TWINHAN TV" folder in CD-ROM and launch the "Setup" program manually.
...(picture)
Step3: Install Driver
Please click "next" to install driver.
Pick the install Software and Driver for PCI
...(pictures)
STEP4: Install TwinHan DTV SDK
Please click "next" to install SDK
...(picture)
STEP5: Install finished
You will see TWINHAN TV icon on your desktop.
...(picture and other instructions - skipping)
This step here is the most important step, makes one choice…and stays with it, after you master or get reception then you can make modification or chose other options. The idea here is to get the card to work…which option is not important.
Step3.1.2
There are two options in this configuration page. If you use BASIC setting (meaning connecting LNB directly to TwinHan PCI-Sat card without other STB; use fixed motor without any switch), please choose "Easy Setup" for scanning satellite. If you have used switch for connecting our card, please select the "Satellite Setup" for advanced setting.
Note: Remember to click "Apply" every time after you change the satellite setting.
...(picture)
"Easy Setup" After you click on "Easy Setup", please choose the satellite that you like to target and click the "Scan" button. You may go to
http://www.satcodx.com/eng/ for more satellite information.
...(picture)
"Satellite Setup"
In satellite setup page, there are five options for you to set up your satellite: 22 KHz, Simple DiSEqC, and DiSEqC 1.0, DiSEqC 1.2 USALS). Choose one for your situation.
Note: You must choose which kind of LNB you are using out of these five options.
There are three types of LNB: Normal/Universal/Custom. If you are using " Custom ",you need to fill in the parameters for LNB 1 and LNB 2.
...(picture)
A. None (Configuration 1)
If you only have one dish and LNB with fixed motor, you may choose this option. Please choose the satellite that you like to target and click the "Scan" button
...(picture)
B. 22 KHz (Configuration 2)
Please choose a satellite you like to scan and the kind of LNB you want to use. Please click Scan button for start to scanning satellite. Please repeat above step for 0 KHz if necessary.
...(picture)
C.1 Simple DiSEqC (Configuration 3)
Please choose a satellite you like to scan and the kind of LNB you want to use. Please click Scan button for start to scanning satellite. Please repeat above step for 0 KHz if you need.
...(picture)
C.2 DiSEqC 1.0 (Configuration 3)
Please choose a satellite you like to scan and the kind of LNB you want to use. Please click Scan button for start to scanning satellite. Repeat above steps for DiSEqC B, DiSEqC C, and DiSEqC D if needed. Please click "Scan" button for scanning satellite.
...(picture)
D. DiSEqC 1.2/USALS (Configuration 4)
Please choose the satellites and select power "ON" for LNB power option. If you have USALS motor, please input the longitude and latitude of your location. You may use driver east/west function to point it to the satellite you want.
...(picture)
Notes for USALS motor?
You could get more information about the longitude and latitude of your location from this website –
http://www.bcca.org/misc/qiblih/latlong.html
Motor?
The Functions of Motor Table
Drive East Turn motor to east
Drive West Turn motor to west
Set East limit Set the limit for East angle turning
Set West limit Set the limit for West angle turning
Cancel limit Cancel the default limit
Go to Sat. Start turning motor to the satellite you have selected (for
USALS Motor Only)
Go to Zero return motor to original (zero) point
Note: If you like to set up Sat2, Sat3, Sat4, and Sat5, please repeat the above steps.
Step3.1.2
When the Scanning is completed, you will see the summary window as shown below. It contains the TV and Radio channels that had been scanned. After scanning is completed, click "OK" to finish this configuration.
If you are having problems after this send me a PM I will give you my phone number call me and I will work with you to get this thing configured and running, ok?
