Can you trun off an Azbox via the remote???
I generally turn off my Azbox by flipping the switch in the back.
I was just doing some experiments to see if the Azbox passed RF through the passthru when switched off, and wanted to compare that to turning off via the remote, which I've never done before. I tried to turn it off, but you apparently can't, at least with the 4585 firmware version I'm using.
What happens, is if I hit the power button on the remote, it takes me to a menu that gives me the options of SLEEP,SHUTDOWN,REBOOT,CANCEL . SLEEP, REBOOT and CANCEL seem to work, however SHUTDOWN takes you into a screen that says it's shutting down, then comes back to a page that says to shutdown now. Ie it seems like if you use that option, you still have to get up and manually turn off the switch in the back. I assume that it is just closing down any open files, and/or un-mounting any directories, etc, but I was under the impression that this isn't necessary with newer versions of firmware anyway, and I've never had any issues with using the switch without doing this first. So I guess the question is, what good is this function if you have to get up and turn the thing off anyway.
BTW, upon trying this SHUTDOWN option, I used the EXIT key, which brought me back to the menu with the 4 options. If I then go into SLEEP, it won't come out of SLEEP. Or actually, it comes out, but the screen has been disabled, and the mouse is non-functional. This is similar to what I've experienced if I try doing a REBOOT from telnet. Ie when the Azbox boots back up, no screen, and no remote. Whenever you get in this no screen/no remote situation, doing a power cycle reboot brings you back to life.
Anyway, I'm curious if anyone else has noticed this, and either know of a way to turn it off via the remote or has some insight into why they have this seemingless unnecessary function whereby you have to use the switch anyway?
