Tuner two output
wayne231
215
Memphis, TN
I have a dvd recorder hooked upt via composite cables to my dvd recorder. The problem is the picture turns into a 4:3 inside a 4:3. What am i doing wrong. oops, it's a 622. any help would be appreciated.
Some channels transmit a HD widescreen image even when their source material is 4x3 SD. This will give you the 4x3 "window boxed" image you are getting. Push the * key on the TV2 remote to switch the TV2 output to "normal". Only use the "letterbox" position if the source material is widescreen HD.
Local Channels Transponder Change
Need Help with Dual Tuner Backfeed with a Diplexer
