I just had the hopper installed from a dish authorized technician about four hours ago. I have called about three times over the last four hours and my call was finally returned. The third tuner will not work no matter what. I called up dish and they had him call me back. He stated you can only use two tuners with the hopper if you do not have a Joey. I know this is factually false. He also told me to wait a day or two for it to start working. I have reset the unit and done dish point as well as check switch. Tuner 1 and Tuner 2 work fine with a signal of 56 (seems low but not sure of the normal signal). The third tuner says lost signal 0% on the meter.
I have been researching and most people point to issues with cables or connectors. Then I saw something about nodes.
The installer didn't install a node. I have a cable from my dish to my hopper with only two breaks in the line. One at a grounding block and one at wallplate.
I do not have any joeys but wanted the hopper for the other features. Shouldn't the technician install a node to split the signal then the switch in the unit itself splits it again?
How should I handle this?
