Triplexer Allow Power Passthrough?
Neutron
Founding Supporter
18,751
1,201
Pennsylvania
Does the DISH Triplexer allow DC power passthrough for an antenna pre-amp?
If not what diplexer can I use that will allow DPP and allow my OTA antenna all on the one cable? A separate cable run is not an option.
try googling power passing diplexer they are available but why should we do your work for you? Being helpful is one thing doing the work is another.
I use Holland diplexers. They allow pass through of power and are rated for 2GHz. Holland DPD2 2 Amp Satellite Diplexer
I believe Neutron was referring to the Dish triplexer, which acts as both a dpp separator and ota/sat diplexer in one unit, not a simple ota/sat diplexer.. It makes for a much cleaner wiring situation behind the unit than using a separator and diplexer.
I may be wrong, but it would seem to me that sending additional DC up the cable could really muck up the LNBs or switch if present.
Can't see 110, 119 & 129 from one location - will this work?
KTVN (CBS) guide data during Sarkes-Tarzian/Dish dispute
