Ok you're twisting my words up here - AGAIN.
The Telephone poles are OWNED by the Phone Company OR the Edison (Electric) as I said before.
IF that was NOT the case, you wouldn't be going out to an accident to see if it's a Phone company pole or a Edison Pole, if it's a Edison pole THEY replace it, if it's Phone Pole the Phone Co. replaces it.
IF you look at one some time, you'll find a tag on it that says so.
I have never seen a utility pole that has power lines on it that is owned by the telephone company. They all have the tag on it that says <insert power company name here> and the pole number or coordinates.
What, you mean that D* DOESN'T OWN the coax that they are placing on the peoples houses that it actually belongs to the Cable Company ?
Thats what you said according to the last statement.
I have no idea where you got that from, because I never said anything to imply that the cable company owns all coax on the planet. But you obviously have no idea what the term 'demarcation line' means. It means any drop (wire) between the pole and a certain point on a house/apartment building/etc belongs to the utility. For electric it is up to the splice between the triplex cable and the masthead (not the meter - even though the masthead carries power before it is metered, it and the meter base belong to the property owner). For telephone it is the NID/ONT, and for cable it is the ground block. If the wiring is damaged up to and including that line, it is the utility's responsibility to repair or replace it at no charge to the subscriber. Anything AFTER that line is the subscriber's responsibility. So like I said, the cable drop from the pole to a house is CABLE COMPANY PROPERTY, whether they are a cable subscriber or not.
There is no such differentiation with D*, Dish, or OTA, because there is nothing that connects to the pole. You are perfectly fine connecting the dish to existing wiring inside the house because it belongs to the property owner. but you have no right whatsoever to use the cable company drops to bridge two properties because that cable belongs to the cable company.
Once I place a line on the subs house it belongs to the SUB.
If it is part of a D* system, you're right. If it's a telco or cable drop, you're wrong.
You should see all the sh*t I see hanging from a pole daily, I understand that I am allowed to take down every clothes line (Subs, not Phone Company) Garage sale sign, Flower bed, that I find on our poles, but do I ? NO, not unless I absolutely have to. But your right, I have the right to.
Well maybe you should start. Then people wouldn't be under the impression that it's OK to attach whatever they want to a pole. I just can't believe you are honestly trying to justify something that's illegal on the basis that you would look the other way.
Now, if you can tell the difference between the coax that the Cable Company uses and the one the Phone company uses (Yes, they use coax to) btw, we all get it from the same company(s) .... No it doesn't say Cable Company ON IT.
Even though this goes back to wherever you got that warped idea that I said the cable company owns all coax on the planet, I'll bite. There is not a telco in this country that uses coax as a customer drop. There's not even a telco that uses coax between a pad site and the pole. It's all twisted pair or fiber. Verizon uses a flexible fiber/twisted 4 pair that is siamesed together for Fios (looks similar to coax) for their drops, and other telcos (like mine) run heavy jacketed fiber underground to the ONT. But no coax, sorry.
IF your gonna climb the pole to check to see if someone drop belongs to you or not, have fun, most companies are tooooo busy to worry about such trivial stuff.
I guess you've never seen the cable companies run audits looking for thieves, huh? Or go up a pole on an unrelated service call? You don't think they would notice that then? Like I said, I don't think they'd be pleased with non-customers using their property to facilitate a competing service.
I've seen peoples Electric wires going to poles, NO NOT EDISON, thier own, are you cutting that down ? Good luck with that.
See the difference here is that's called a 'yard pole'. They are very common in these parts. They usually have the customer's meter and breaker box attached to them, and they feed outbuildings like barns and pumphouses. But they are inside the demarcation line, and belong to the property owner. If something knocks it down, the property owner is responsible for replacing it before the utilities will reconnect.
I've seen people running power from one house to another, NOPE, I'm not touching it.
If it's not attached to a utility pole, you have no right to. But if it did, I'm sure a power company tech would have no qualms about snipping it AND disconnecting service to the other house to make sure there isn't a live line laying there. Then I'm sure it would be reported to the code enforcement office.
IF I decided to run a coax from my house to the one across the alley YOU would NEVER know it. (I don't have any alleys here, so you don't need to look).
Maybe not.. But if I did you wouldn't have a leg to stand on if you (or the neighbor) had no TV one day and found your line laying in your yard, cut. You also wouldn't have any defense if you got a ticket for it, because it is ILLEGAL. Ignorance is not a valid defense.
