transponder change
Meriah
Did direct tv just change some transponder, seems HBO1 changed to 27, does anyone else have trouble getting some of the odd transponders?
Where are you located?
If you are losing all odd or all even transponders, you probably have a hardware issue, since losing only odd or even xponders usually indicates LNB problems.
If you are losing only some odd or some evens, you may have a line of sight issue, like trees.
If you have a multiswitch, bypass it, preferably with a fresh coax run to eliminate a switch/coax problem.
NFL Network HD Preseason
Is this info correct about a new customer?
