I have a 2TB EHD connected to my Wally; I think it's starting to fail. Is there any way to connect the "new" EHD to the 2nd USB port and transfer the recordings over so I don't lose them all?
Buy a hardware RAID 1 enclosure. Put as near identical HDD in it as you can. Put your "failing" drive in it also. Power it up. Sleep on it. With luck, in the morning, you will have a usable clone.
Wally/ViP211/Vip411 are the stepchildren of DVR's. Only one drive may be attached at a time AFAIK. Way back when the 211 first came out there was a discussion about cloning the drive on these machines with Ghost, Acronis or some other software that does bit by bit copying.
Another method was to create a second drive (hopefully a new piece of hardware) and connect both to a linux computer and copy the programs manually from the Dish ARC folder on the old drive to the DishARC folder on the new drive.
I don't even remember if it was on Satelliteguys.us or the "other" place, but I believe it was done by the user PSmith, but it has been probably 7-8 years so details have faded.
I like this idea but... I've never personally used a raid 1 enclosure that did that. Always the first step is to format both drives. Do you have some recommendations on enclosures for which this definitely works?
Actually, you can transfer your recordings from one disk to another. I just expanded my 1TB drive almost full, to a 4TB Drive.Nope...
