I have been around the world and back via Google, and I think I've read and done everything suggested, but the folks here seem very sharp, so here goes:
First, I should say that after repeated failures connecting to the outside world (can not find server), I burned the latest firmware to a CD, and confirmed, the device is already at 1.3.
My setup:
Verizon FIOS w/ActionTech MI424WR router. Connected to that, is a Linksys EZXS55W switch in the living room.
Experience so far:
My iMac, Windows XP box, and Brother network capable laser printer are all hardwired to the ActionTech router and work fine.
In the living room, my Mac Mini and DISH VIP-722 DVR are connected to the Linksys switch, and also work fine.
All of the above devices are viewable, pingable on the network, and all access the outside world just fine.
Now as for the HD-A3:
Whether direct wired to the ActionTech, or via the Linksys switch, the same thing occurs (or doesn't, as the case may be):
I step through the ethernet setup, and when I set DHCP and DNS to "on", and power cycle the device, the gateway, and DHCP addresses always show all zeroes. It does not connect to the outside world, nor can I see it on my network.
If I manually configure it and allow it as follows:
IP: 192.168.1.4 (although other IP addresses are free as well)
Subnet mask: 255.255.255.0
Gateway: 192.168.1.1
DHCP server: 192.168.1.1
With that setup, I can see the HD-A3 on my network, and I can ping it successfully. Still though, it "can not find server".
In other words, nothing I have tried has resulted in this thing being able to see the outside world. I have confirmed the gateway and DHCP addresses are exactly what my Mac Mini and other devices on the network are using.
So:
Are their ports that I need to open for this thing? I spoke with a Toshiba rep yesterday, and he's supposed to e-mail a document from their Japanese Engineering group that references port configuration. Still though, I have seen no other posts anywhere indicating this should be necessary.
Any advice would be much appreciated. On one hand, it would seem defective, but I'm not buying that, because I can see the HD-A3 on my network.
This is very frustrating, and I'd sure like to see what these web-enabled discs are all about ("Transformers" for example).
Thanks very much in advance.
My setup:
Experience so far:
So:
