Timer Alert: 11/20/2012 Glorystar Update
Effective 11/20/2012 update: Due to a channel list realignment, existing event timers may have been shifted up by one channel. If you have existing timers programmed in your GEOSATpro DVR1100, DSR100 or DSR200 receivers, any timers programmed on or before November 19th will have shifted up to the next channel.
Example: If you had set a timer for channel 100 - Daystar, the timer will now reflect the channel to be 101 - TBN.
You will need to manually change the channel in the timer back to the desired channel. Example: If Timer #1 is supposed to record Channel 100 - Daystar, simply open the timer and change the channel back to 100 - Daystar.
We are sorry for any inconvenience that this channel list realignment may have caused. We do not anticipate that this event will occur again.
Have a Happy Thanksgiving!
GEOSATpro DVR1100c does not playback recorded files anymore
ReAimming Satelite
