Well came home today and decided to ground cables that indy tech guy did not as per my main post. Well I first pulled cable off position for receiver 4 as its hooked to a legacy and dont need it because I dont have legacy adapter. Then I moved cable in receiver out position 4 to position 3 and put plastic weather cap on position 4 (not used) So my DPP-44 goes as follows. 119-110-129 as put in by installer in Sat in's. Receiver 1 output goes to main 622 with power inverter connected in house by installer then to 622. Out put 2 goes to a 322 about 3 feet from switch inside kids play room. Works fine. Output 3 goes to master bedroom 508 and Output 4 dead.
Well after I hook it all back and run better drip loops I go inside and powered back up inverter and main receiver. Ran check switch and 622 works fine.
Downstairs 322 next and works fine.
Here is why I think switch failed. I go upstairs and 508 has froze screen. I ask wife this this just happen? She said NO, she was watching TV in early afternoon and screen froze. She forgot to tell me. So I am clear that it did not happen from me.
Just to be sure I checked and all cables are fine, no shorts as checked with my volt meter. I just to be sure re-booted power inverter and tryed check switch multiple times at 508. NO SWITCH DETECTED> Also hooked up the 510 I turned off when getting 622 and it actually will not turn on. Safety was not allowing it to turn on when input cable connected at back. As soon as I disconnect cable from switch it will power up. So it must have a short in switch I assume and 510 is catching it and protecting itself.
Yes I tried moving the output to different position expect main number 1 that is with 622 and power inverter. No luck! No signal on antenna check either.
I am at my wits end. This 44 is less then 24 hours old!!!!
Any thoughts!
Any thoughts!
