Not too much. The trick is remembering to turn on the gas under the right side of the hood. If you forget that the rest doesn't matter.That IH looks identical to one a deceased friend of mine had. As I recall, starting it was a bit complicated.
Mount a dish on the tractor so it would be a dish farm on wheels.
Outside of Farmall, there are only 2 tractors I would buy: A Ford xN series and an Oliver Row Crop. I have the sickle bar for it, about 70% restored, but I'll never have a use for it so I'm thinking off selling it in the Spring. I'm currently refinishing the 54A push blade and since the sickle and the blade use the same mounting holes one of them becomes redundant and I have more use for the blade.My Farmall Cub is a 1955, starts easily with the crank if needed. Completely original and runs great. The Ford 2N is a 1947 model. Engine rebuilt and converted to 12 volt electrical system.
