The List: 87.0°W AMC 3 C missing Audio Channels for 4043 H 3909
Lassar
SatelliteGuys Guru
149
Illinois
"The List" is missing the audio channels on 4043 H 3909 on 87.0°W AMC 3 C.
"The List" only shows one audio channel.
I know for a fact there is at least 8 channels. Probably 15 channels or more.
How about rescanning the transponder, and adding them to "The List".
There is technically only one station that logs. There are like 20 audio streams in that channel. I see that "the list" has been updated. Previously I remember there was all the streams (audio pids) listed (because I had to manually add them). You would just use the "language" or "audio" button on your remote to go through them
Its like the Dial Global feed that (might still be)is on 139W. It logs one channel and then you can use the language button to find the right one. I see that one wasnt updated so here is how that feed on 87W would look
http://www.satelliteguys.us/thelist/index.php?page=C+139+AMC+8
One logged channel...multiple audio streams
I rescanned it on my Glorystar.
Info shows language 1/4.
It only shows 4 out of approximate 20 audio streams.
To get all those audio streams, I have to get the audio pids from a list, and manually add them vita "Channel Master" editor.
Here are the pids if you need them.
Freq pol sym rate sid description apid pcr
4043 h 3909 1 Service 1 (VC1) 0 280 8190
4043 h 3909 1 Service 1 (VC2) 0 290 8190
4043 h 3909 1 Service 1 (AMC) 0 700 8190
4043 h 3909 1 Service 1 (LF1) 0 5069 8190
4043 h 3909 1 Service 1 (CB1) 0 8000 8190
4043 h 3909 1 Service 1 (SR1) 0 4737 8190
4043 h 3909 1 Service 1 (SR2) 0 4972 8190
4043 h 3909 1 Service 1 (SR3) 0 5029 8190
4043 h 3909 1 Service 1 (SR4) 0 2592 8190
4043 h 3909 1 Service 1 (SR5) 0 2593 8190
4043 h 3909 1 Service 1 (SMA) 0 7249 8190
4043 h 3909 1 Service 1 (SMB) 0 3719 8190
4043 h 3909 1 Service 1 (SMC) 0 5587 8190
4043 h 3909 1 Service 1 (SK2) 0 8076 8190
4043 h 3909 1 Service 1 (SNN) 0 4093 8190
4043 h 3909 1 Service 1 (IU2) 0 5634 8190
4043 h 3909 1 Service 1 (IU4) 0 6346 8190
4043 h 3909 1 Service 1 (RR1) 0 6950 8190
4043 h 3909 1 Service 1 (CB2) 0 750 8190
4043 h 3909 1 Service 1 (SR6) 0 102 8190
Some chipsets have a limit on APIDs per mux, wouldn't call this a flaw. Many model receivers will scan 10 or 20 APIDs and others will log all audio PIDs without manual entry.
The way this particular mux table is built, STBs see the service as only one audio service with multiple language tracks.
Brian Gohl
Titanium Satellite
Well, I learned something new today, all is not lost!
Looking closer I have the 20 audio PID's in the 'one' channel.
Your list looks interesting.
Are you sure, you are getting every audio stream?
Moody audio pid 1276 is missing from your list.
That’s from a scan I did with my HDstar usb receiver on 3/27/14. I can’t guarantee it to be 100% accurate, but probably as good as any other list you may find.
There are 20 defined channels in the SI stream. Other undefined services are using IP delivery instead of MPEG2 audio like the above 20 services.
Moody changed their distribution from MPEG2 audio to something else a few months ago. I'll have to check your "audio pid 1276" reference to see if it's there as MPEG2 audio and needs to be manually defined since it is not in the SI stream or if moody is IP on that pid, etc.
"Welcome Back Kotter" is now on MeTV
Brand loyality STACK
