Hi there
I receive a pretty good signal, 88% on transponder 11806 V, I'm using a 3ft dish with universal LNB that I have to install upside down due to the low elevation of 15W.... i'm located outside of Toronto, Canada (town of Milton)
When I run the transponder scan, it seems like the only channels that come up are the ones that are not MPEG4/DVB-S2
ie: Alalam, IRINN
I used the Dreambox 500s built in satellite find tool. I noticed that 11806 V was pretty much the only transponder that gave me a lock at > 80% signal strength/quality, the rest of the transponders indicated an increase in strength (~65-70%) at this point, but none of them locked. I was wondering if this was because of my receiver, since DM500s is made for MPEG2/DVB, but most of the transponders on 15W are using MPEG4/DVB-S2.
Another variable in this was that I had a connector in between 2 coaxial cables (from lnb to receiver), the connector was a grounding block...its all I had at the time to connect the two cables...i wonder if the grounding block interfered with the signal integrity of MPEG4/DVB-S2 compressed data.
I'm trying to get my hands on a newer HD fta box (MPEG2/H.264/MPEG-4) to test this theory out. Would anyone be able to provide any insight on this? Which receiver do you use on Telstar12 - 15W to get Chilevision and from what I understand, some TuVes channels?
Thanks in advance to anyone who can provide more info on this.
ie: Alalam, IRINN
