TechnoTrend is not Locking Signal
harish_agr
Hi,
I am facing one serious problem when using techno trend device [TT S2-3600] for tuning to live signal.
I am trying to tune live signal through Techno Trend device [TT S2-3600] directly from Satellite Dish. In this Scenario, Satellite Dish needs LNB voltage and 22 kHz tone from digital receiver [In my case TT S2-3600]. For this, I have to supply LNB voltage and 22 kHz tone output related information in to DirectShow. but how ?
The same scenario is working with TT S-2400. When I connect S2-3600, DirectShow is throwing an Error in IMediaControl.Run() function. It returns value is “1” [I guess it is equivalent to false].
This problem is occurring only when I connect TT S2-3600 Direct from Satellite Dish [There is no other h/w in between Dish and Techno Trend]. However same TT S2-3600 is working in when I connect it with distribution system [Where some hardware connect in between Satellite Dish and TT S2-3600]
Please let me know if you need any further detail in this regard.
Harish
Which DVB app are you using and what are lof and switch settings?
What type of lnb are you using (universal?)?
I am using a private application. I am supplying the follwing setting in to BDA Wrppaer.
1. Frequescy
2. Modulation [QPSK]
3. LnbHighFrequency
4. LnbLowFrequency
5. Polarization
6. SymbolRate
7. FEC
Apart from this I think I should supply LNB Power and Command22KHz parameter. But I don;t know how to supply this two parameter in my BDA Wrapper so it can be used by DirectShow.
Please let me know if you need any information in this reagrd.
I really need this help....
Harish
FTA Receiver with ATSC Tuners + PVR
Sony Entertainment Television
