Just came back from vacation and had freezing on one HR24. (didnt check the others) The next morning there was a 775 error message on both HR24s and the H24. Called ext 775 and they had me unplug the SWM. Still no picture, still error 775. About a half hour latter picture was back on all units. It went out once more and then back on.
The next afternoon all the units were operating properly when the DirecTV tech arrived. He found a bad connection on the feed wire to the SWM coming out of the wall jack. He replaced the SWM and also the LNB. Everything was working fine when he left. He said I had 100's on some of the transponders. Then this evening the 775 was back again.
The tech was concerned about the run from the dish to the house. It is aprox 300 ft and is RG7 instead of 6. He said that the SWM is only rated for 120 ft. The thing is, this system has been working flawlessly for 8 years, and the RG7 is much lower resistance than RG6. He stated that he usually tests the voltage by touching the wire with his hand, and I dont have as strong a jolt as he is used to.
I have been thinking of changing the H24 to a Genie, and I asked him about it. He stated that he would not use a Genie with my setup as he said the Genie is much slower than the units I have and could have problems with the run. So I asked about moving the dish closer to the house as we have had some trees taken down and I though we might have a good view of the sky. He says DirecTv no longer will pay to put in a pole. The new run would be about 50 ft. He said it would probably cost $100 to $150 out of pocket.
So first question is, are there any thoughts on getting the 775, knowing that he replaced the SWM and LNB? Second any thoughts on the run of RG7? and third, if they wont pay to put in a new pole, what do they pay for?
Tech scheduled for tomorrow morning. wish me luck
Pete
Pete
