I installed a swm-8 a couple of weeks ago.
I added an external HD antenna to the ota port at that time.
My dvr and one other receiver will not work with the diplexers. The one receiver that accepts the diplexer works like a charm. The other 2 receivers, I removed the diplexers and I get loss of picture at least a dozen times a day, with a 771 message on the screen.
Direct tv wants $49 for a service call because I installed the swm myself, so they are coming out in a few hours. The tech tells me on the phone diplexers will not work with swm8's.
Is he wrong? I think so.
The Direct Tv tech left a while ago and first told me I was using the wrong SMW. He said I should be using a SMW5 instead of the smw8. I have all the correct equipment installed and installed correctly. He then told me there is not enough power for the ota to work on my 3 receivers. Then he told me the swm8 will not work on my 3 receivers.
I have a h20-700 DVR, and 2 h20-100's.
The diplexer works on one of the h20-100's.
All specs I read lead me to believe the swm8 does and should work on my receivers.
All this info from the tech for $49 and he never looked at my receivers, just the power supply in the cellar.
Am I correct in my info?
