I live in central Tampa (33618) and had an old RadioShack omni antenna placed by an electrician years ago that worked for several channels.
I want to revamp my antenna. I have a tall 2 story house.
yellow - uhf WTSP-DT 10.1 CBS ST. PETERSBURG FL 304° 19.1 24
yellow - uhf WTOG-DT 44.1 UPN ST. PETERSBURG FL 138° 19.4 59
yellow - uhf WTTA-DT 38.1 WB ST. PETERSBURG FL 139° 19.8 57
yellow - vhf WFLA-DT 8.1 NBC TAMPA FL 139° 19.8 7
yellow - uhf WEDU-DT 3.1 PBS TAMPA FL 138° 19.4 54
* yellow - uhf WCLF-DT 22.1 CTN CLEARWATER FL 141° 20.9 21
* yellow - uhf WFTT-DT 50.1 TFA TAMPA FL 139° 19.8 47
* yellow - uhf WXPX-DT 66.1 i BRADENTON FL 141° 20.9 42
* yellow - uhf WMOR-DT 32.1 IND LAKELAND FL 141° 20.9 19
* yellow - uhf WFTS-DT 28.1 ABC TAMPA FL 139° 19.8 29
* yellow - vhf WTVT-DT 13.1 FOX TAMPA FL 139° 21.8 12
* yellow - uhf WUSF-DT 16.1 PBS TAMPA FL 138° 19.4 34
* lt green - uhf WVEA-DT 25.1 UNI VENICE FL 141° 20.9 25
All the stations are 21mi or less. There are two VHF (one high one low) and CBS is 160 deg off the rest.
I saw some posted options for a Tampa member that was 25mi out that included two antennas or one antenna with Rotor.
Any chance a good omni would work? Or I saw that the Wineguard GS2200 has bi-directional. Its not a perfect 180deg off but 160deg might work?
Lastly, if I split the signal 4 ways can you recommend a splitter.
Thank you.
Thank you.
