jimdandyvi said:I would suggest continuing to use the inverter. Just set your truck up with dual batteries like a boat. Use one battery for starting and the other for the tailgating setup. You can get the switch and cabling you need at a marine supply store. Use a deep discharge battery to run your accessories.
Generators are noisy and require lots of maintenance. Just be sure to check your load using a kilowatt meter to be sure you are not overloading the inverter.
On the flip side, what kind of inverter are did you use to have problems with?We use to use an inverter and batteries and that was a pain in the butt. Wasn't the most reliable either. That's just my experience though.
Generators are a lot of maintenance? What crappy generators are you using? My generator is very quiet and extremely easy to use. I am terrible at taking care of most things with an enigine but have no problem managing the honda generator.
I have a couple of generators I need to replace the carbs on, I cleaned them myself but still no luck... I bought a propane powered generator to eliminate that problem, but it would be too big for tailgating. http://www.tractorsupply.com/sportsman-4000-watt-portable-lp-propane-generator-1012003A generator needs to be run regularly to keep the carburetor working well. I learned the hard way last year because we went to use our seldom used generator during a storm, it wouldn't start. We seldom use the generator because our inverter system works so well. The repair was a new carburetor.
The repair facility was very adamant about not using ethanol gasoline in engines not run regularly. Fuel stabilizers don't handle the water combining with the ethanol well. That is a real challenge as it can be very hard to find non-ethanol gasoline. When we winter in Mission Texas, the closest source of non-ethanol gasoline is Corpus Christi. Luckily, here in Hayward Wisconsin, the three gas stations in town all have non-ethanol premium gas, so we stocked up.
dfergie said:I have a couple of generators I need to replace the carbs on, I cleaned them myself but still no luck... I bought a propane powered generator to eliminate that problem, but it would be too big for tailgating. http://www.tractorsupply.com/sportsman-4000-watt-portable-lp-propane-generator-1012003
Very, turn on propane, starts first pull so far... plus the fact I live in the country and can fill my own bottles and propane is much easier to haul than gas, for hunting I'm either getting a 50 lb bottle or taking one of my 100 lb's ... I am considering a tailgater as I have a 211k, I normally take my Directv dvr and a Directv receiver, but it takes time to set up.I have looked at that gen before.
Are you happy with it?
