Hello,
For the last several weeks, my high-speed internet connection has been unreliable. The connection would drop and then the cable modem would reset and connect again. The problem is worse when requiring high bandwidth (online gaming, Netflix streaming movies, etc.).
Here is the modem log:
I contacted Cox and Tech Support said it was the modem. I picked up a new modem at the Cox store. Problem still continues.
I contacted Cox again, Tech Support said it was the router. Plugged PC directly into cable modem (bypassing router). Problem still continues.
I contacted Cox again, Tech came over. Checked indoor lines. Everything looks good. Replaced outdoor box. Problem still continues.
I contacted Cox again, Tech elevates my issue to Tier 2. Research online says problem is something in the neighborhood. Bad node. Bad line amplifier. Hardline Dist. Plant problem.
This is very frustrating. Any suggestions?
-sacolton
2011-10-31 04:26:06 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:26 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
1970-01-01 00:00:07 | 6-Notice | M571.1 | Ethernet link up - ready to pass packets |
2011-10-31 04:25:25 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:25:25 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:24:52 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:24:42 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:24:41 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:24:41 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:24:39 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:22:59 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:23 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
2011-10-31 04:22:21 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:22:21 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:21:49 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:21:38 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:21:37 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:21:37 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:21:35 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:19:24 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:22 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
2011-10-31 04:18:47 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:18:47 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:18:14 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:18:04 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:18:03 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:18:03 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:18:01 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:10:13 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
2011-10-31 04:09:36 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:09:36 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:09:03 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:08:53 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:08:52 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:08:52 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:08:50 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:06:10 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:24 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
2011-10-31 04:05:32 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:05:31 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:04:59 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:04:48 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:04:48 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:04:46 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:02:07 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:25 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
2011-10-31 04:01:26 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 04:01:26 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 04:00:54 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:00:43 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:00:42 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 04:00:42 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 04:00:40 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:58:34 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:00:27 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
2011-10-31 03:57:52 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 03:57:52 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 03:57:19 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:57:09 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 03:57:08 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:57:08 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 03:57:06 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:54:26 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
2011-10-31 03:53:44 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-31 03:53:44 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-31 03:53:12 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:53:01 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 03:53:01 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 03:53:00 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-31 03:52:58 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-31 02:08:38 | 4-Error | D103.0 | DHCP RENEW sent - Invalid DHCP option |
2011-10-30 14:08:50 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:03:38 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
1970-01-01 00:03:21 | 6-Notice | M572.0 | Dhcp Init Failed - Reinitialize MAC... |
1970-01-01 00:03:21 | 3-Critical | D002.0 | DHCP FAILED - Request sent, No response |
2011-10-30 14:04:57 | 6-Notice | M573.0 | Modem Is Shutting Down and Rebooting... |
2011-10-30 14:04:56 | 3-Critical | R004.0 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o |
2011-10-30 14:04:24 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-30 14:04:13 | 4-Error | C401.0 | DCC-ACK not received |
2011-10-30 14:04:13 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-30 14:04:11 | 3-Critical | R005.0 | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
2011-10-30 13:32:24 | 6-Notice | I401.0 | TLV-11 - unrecognized OID |
1970-01-01 00:07:05 | 3-Critical | D003.0 | DHCP FAILED - Requested Info not supported. |
1970-01-01 00:06:51 | 3-Critical | T001.0 | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
1970-01-01 00:06:46 | 3-Critical | T002.0 | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
1970-01-01 00:06:46 | 3-Critical | T001.0 | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
1970-01-01 00:06:39 | 3-Critical | T002.0 | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
1970-01-01 00:06:39 | 3-Critical | T001.0 | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
-sacolton
