T-55
Toddytime
66
East Tennessee
Does any one know if the T-55 toroidal dish which can take up to 8 lnb's can be had with the proper lnb's for the new directv and Dish sat's?
I see it listed on e-bay and wonder if it's a good buy to have it loaded up with lnb's for both Directv and Dish along with proper switches.
Same effectiveness of 55 cm (20 inches) dish for each LNBF installed
Can accommodate up to 8 LNBFs
Covers up to 40 degrees in arc (60 degrees in azimuth)
Superior to any rotary system
Multi-beam Antenna uses Toroidal Formula , is designed to reflect signal twice through the main reflector and sub-reflector
Receives many satellite signals simultaneously using only one dish
You might want to post this in the MPEG/FTA section as most of the users of this dish, and its big brother Wave Frontier T90, would be hanging out there.
Have dish thinking about Direct receiver questions
Phillips mrr 660 stuck turning itself off and on
