SWM issues DRIVING ME CRAZY
dabird
United States
I have a situation that I need help with. I have 1hddvr, 2 h25 and 1 d12 hooked up with a SWM system. I am getting intermittent "Searching For Satellite" on various recievers. The signal is only on one Rec. but not always the same one. There is no rhyme nor reason to it. I have replaced every piece in the system. I have it wired as follows. LNB, approx. 8' RG6 to SWM2, Power passive side to PI21, other port to SWM4, from SWM4 to recievers. Any ideas would be helpful I'm pulling my hair out
Try eliminating the swm2 splitter, no need for it if I read your config right. Connect the swm4 splitter right to the PI, then run one line to each receiver. Check all connectors, signal strength on the receivers too. Need to identify if it is one satellite or all that are showing problems too.
WELCOME to Satelliteguys!
:welcome to Satelliteguys dabird!
I'll echo what jcrandall said, you only need one splitter.
on your pi is the (to receiver) port terminated? but like has been mentioned I would try and eliminate the 2way splitter. On the 4 way splitter unscrew the cable that says power pass ( on the receivers side of course ) and go inside and find which receiver says searching for signal/ problem communicating with dish. which ever one says this is were u will want to place the pi. From your wording in the question you sound knowledgeable enough to figure out how to do this without a step by step guide so I will stop here, but if you get lost post back I am sure myself or some of the other guys here can get u back on track. Btw u mentioned rg6 from dish to first splitter, what is the cable inside the house? Do you have wall plates or through floor/wall? If wall plates what color is the center of the barrel connector in it? If wall plate have you checked behind it and seen what type connectors are on it. I have seen the white/clear center barrels and the crimp on connectors cause this problem before.
problems with the HR34(genie) with hr21 and two h23
Question about using new Genie system
