Ok guys,
I need some help/advice ....
I have a D* set up at the 5th wheel at the campground.
Signal is fine, high 80's mid 90's.
Heres where my issues are coming from.
In the last week I have changed the home over to the SWM set up.
All recvrs working fine.
I took a H20 out to the campground today at use this weekend.
When I set it up as I always would, I went into the menus to Repeat Sat Set Up because I didn't expect it to work with the dish at the campground (which it didn't) campground is a Slimline 5 .....
When I got into the Sat set up once you hit the checkmark, it shows the Dish configure page, where you would select the correct dish in the background and sits at Please wait ...... forever .... and times out and goes to screen saver, coming out of screen saver it will resume Please wait , waited about a half an hour and retried.
I am unable to change the DISH back to the SLIMLINE from the SWM because the screen changes so quickly.
I know that when I hooked up my SWM at home when I went into set up, it changed to SWM right away once it detected it, a few seconds.
Is there a trick to get this H20 back to SLIMLINE anything special I need to do ?
My switch to SWM went smooth, going back for the 5th wheel is anything but.
