So I am going to be swapping my swm 8 out with a swm 16. For my current set up I have 1 line coming off of the SWM1/PWR going into the power inserter, then the 8 way splitter is fed by the IRD port of the power inserter with the DVRs being fed from the 8 way splitter. Is this type of set up NOT recommended for the SWM16? I notice in the pictures & wiring diagrams for the 16 that I have seen, it appears there is a dedicated PWR port on the SWM unit that is being used to ONLY go to the power inserter.
My plan is to feed the HR44 directly from one SWM port & feed the splitter from the other SWM port. Can I still feed the splitter from the power inserter connected to the SWM1/PWR port on the swm16 like I do with the swm8? Will it work this way or do I need to feed a dedicated power line to the power inserter from the DC/PWR port & a separate run to the splitter straight from the swm16?
I also noticed the lack of an OFF AIR port on the swm16. I assume that it's not possible to diplex an antenna connection with the swm16 like you can with the swm8?
thanx!
thanx!
