Maybe because it would be too easy to change the mode by mistake?
That is not a good reason, I am not talking about a single dedicated button.Maybe because it would be too easy to change the mode by mistake?
That's what I was thinking too. It would probably be a pretty large call driver (same goes for closed captioning)
I have to agree. Bogus reason, especially since every tv remote on the market has a CC button.So you're saying if they had a CC button, that would drive up your calls? I've talked to so many people who hate it that they can't change the CC on their cable box or dish box by a simple button.
Maybe NOT. Maybe most people don’t understand the full potential of the Mode function and that is why "there is no demand for it". Maybe Dish screwed it up by not adding the Mode switching to the Menu. Placing the Mode switch (any place) in the Menu would require at least 3 distinct key presses so people that don’t know what they are doing cannot change the Mode by "mistake". As far as switching between Single and Dual Mode interfering with timers, it is nonsense.Maybe because most don't change modes once they are setup in the mode they need.
I agree completely with your first statement.Maybe NOT. Maybe most people don’t understand the full potential of the Mode function and that is why "there is no demand for it". Maybe Dish screwed it up by not adding the Mode switching to the Menu. Placing the Mode switch (any place) in the Menu would require at least 3 distinct key presses so people that don’t know what they are doing cannot change the Mode by "mistake". As far as switching between Single and Dual Mode interfering with timers, it is nonsense.
Here is the main reason that I would like to be able to switch the Mode with the remote. Receiver’s TV1 HDMI output goes to my HDTV in the living room, TV2 output SD (coax) goes to my HDTV in the bedroom. How do you watch HD on your TV2 and still be able to operate your TV2 independently of TV1? (Don’t tell me to get another HD receiver). You simply add a cable from your receiver’s TV1 component output to your TV2 in the bedroom (if you prefer, you can swap the HDMI and the component cables).
Now, if no one is watching TV1 and you want to watch HD on your TV2, you simply switch the receiver Mode to Single and switch the input from the coax to your HD input and you are watching HD on TV2. If someone is watching TV1 and you don’t like what they are watching, you switch the Mode to Dual and you are back controlling independently your TV2 as before (of course in SD). You can still do this trick using the front panel Mode switch, but it would be a pain in the butt.
You are correct that you can accomplish similar functions with your suggestion, but I don’t think it would be very practical.I agree completely with your first statement.
However, you can accomplish what you're talking about with no mode switching at all, just get another UHF remote and assign it to TV1. Then switch your remote TV between RF-input and HD-input all you like, swapping remotes when you do so. All outputs are always active, so switching between the two is as simple as changing the active input on the TV.
The sun does not revolve around the Earth; the Earth revolves around the sun.
