ok I've used both of these first the 22k , and then the 4 in 1 DiSEqC with my QPH031 ( to combine Linear & Circular) well i don't really know if i've been using either switch right
Question .....the 22k had the l&c go into one coax and then to receiver. i'm sure i got L through the switch but not sure about the C do you have to set the 22K to on in the coolsat menu to get the circular side. do you have to set up two sat for each if you want to get L & C from the same satellite??
ok now the DiSEqC had it set lnb 1 was the linear side & 2 was the Circular side then the receiver out. i never set anything in the menu so i guess i was just getting the linear side .
question ....to get L & C side i need to set DiSEqC in the coolsat 5K menu to
1.0 or 1.0/ 1.1 ... ?? 1.0 allows only 4 committed 1.0/1.1 allows 4 committed & 16 uncommitted
question ....since i only had 1 & 2 lnb set i should set it to 2 correct
or do i need to set 1 for the l side & 1 for the c side creating 2 sats one for each.
don't know how i had things working before
