Switched receivers, now no signal...
jjnemoiii
234
i just received an H20 Mfr. 100 receiver from an Ebay purchase (Directv had none left, 2 calls). Replaced an H21-200 that got great reception for all my channels. Unhooked satellite wire W/ B-band converter from H21, hooked to H20. Same with HDMI cable. Went through satellite setup on H20, no signal from any satellite. Cables back to H21, great reception. Not sure, in H20 setup, if I have 6x8 or 4x4 multiswitch on the slimline dish, but with either setting, no signal at all...
More info... When hooking cable back up to H20, found Satellite jack to be spinning (Coax connector). Tightened up thin lock nut to case, it no longer spins. On H20, for some sat's, reported number of transponders is different -
H20
99 (net 10) 0 transponders
99 (net 11) 0
103 (net 14) 0
103 (net 15) 0
H21
99 (b) 6 transponders
103 (a) 16
103 (b) 16
H20
99 (net 11) 0
103 (net 14) 0
103 (net 15) 0
H21
103 (a) 16
103 (b) 16
You got a bad box...
Thank you for the help, and finally, yes, less than 28 days to the start of 2008 NASCAR!!!
4 HD DVR's, how to hook up?
Significantly Viewed Channels Question
