Switch Recommendation Anyone?
BubahJim
64
Bluefield, VA
Hi Guys,
Need some advice. I am running a Wingard 2076 dish with a SG 2100 motor into a fortec ultra reciever. I also have a pair of Fortec 80 cm dishes on a Diseqc 4 way switch. I want to combine them together. What switch would you recommend using? I tried using the Diseqc switch but it could not handle the motor.
Jim
weird....
my switch was between the receiver an motor and it worked fine
What you could do is put it after the motor and on the 2 dishes that are fixed, set the motor to off or disable...then it won't move when you switch to those dishes
pansat 2500 dish pro500 0 quality
Why is Collsat 4000 Pro twice as much as Fortec?
