Greetings to all!
I have been a bit of an experimentalist for many years on and off, mostly with the Dish/Bell equipment used on an old viewsat rec for FTA (real FTA, not the illegal stuff). I am also very fluent in structured cabling.
Recently, I have been given the opportunity to set up a sat system in a rural area. The problem I am having is finding the right equipment for the job, specifically the switch.
The owners of the property want to have each of the 8 TV locations to have the ability to run a dual tuner receiver (whether they actually use it or not). I suppose in that case I am looking for a way to do 16 outputs from a 2 dual LNB dish. I know I can use the SW44 x 2 with 4 high frequency splitters but I'm sure someone has put together an all-in-one switch that can do just that. There is no OTA or other TV services going in, as far as I know.
The good news is it's a new build and the walls are open... for 3 more days. I have run 2 quad RG6 cables to each receiver's location. An installer told me I could get away with 1 quad and use some sort of switch at the receiver end to split it back into two for the dual tuner.
Any help here would be great! Options and opinions are always good so fire away!
Thanks in advance,
Shandley
Thanks in advance,
Shandley
