Spent a lot of time trying different things to fix this issue so now I'm here. I will try to cover all of the things I did since they will be suggested. It's 20 H-25 and 4 H-24 receivers supplied by three 8-way splitters. About once a week, the same 8 H-25 receivers that are fed from the same splitter would go offline with a 771 or 775 error. It didn't seem to be tied to power failures or rain but not 100% sure since I'm not always there. The only way to fix it was to pull the plug on the two power inserters. I found a SWiM 8 being fed from the Legacy Ports of a SWiM 16. The TVs that would go offline were on the SWiM 8 and I read that the Legacy Ports are not the best way to feed another SWiM. So I got an E-2 adapter and joined two SWiM 16's together. The issue continued so I replaced the splitter. The issue continued so I tried moving the coax that feeds the splitter to the other SWiM. The issue continued so I tried swapping the power inserters between the SWiMs. The issue continues so I put a smart outlet at the two power inserters so I can reset things without having to be there.
I understand power failures and rain can throw things offline but why is it always the same 8 receivers and the other 16 don't have the same issue? The smart outlet is a temporary fix but not a permanent one so any other things to try are appreciated. Thank you!
