Suspend/Disconnect and still view recordings?
Didn't I read somewhere on here that if you disconnect your box from the dish and internet so it doesn't get the terminate signal that you could? Never had the occasion to try it though.
Maybe not.
It is also different on different receivers with different results. The short and simple answer is "no it will not work". The more complicated answer is "you can try it, you might get lucky, but if it cuts off, you were told it was not supported." It is a game with the receivers.
Material Archived to external drive disappears
