I have a superdish that was used for reception of 119/110/105 when they first came out(2004?). I am at 32408 panama city florida. The 105 is not required for my locals anymore.
I have lost the even transponders from the 119 lnb/dual feed on both receivers. Prior to lost, the 119 would only work in early morning, or late evening after the temp went down. Today the symptoms have become steady no 119 evens, and sometimes nothing at all on both receivers. Check switch shows odd for 119,dual. The dish has three lnbs, each independent, the 119 and 110 have two connections, and the 105 has a single connection that go to the dp34 switch.
What type of lnb do I look for in the used market/after market to replace the 119 dual lnb.
model number ect.
Easy to swap, since its on an outrigger, one screw, and one connection to switch.
System uses superdish, sw34, 811, 311 and 119/110 satellites, no hd requirement.
I have seen posts about something called stacked, however, I am not sure how this plays with the 119/110 lnbs.
Bob
model number ect.
Bob
