What type lnbs are used for the superdish? Can't really seem to find much info on the system at all. what's the difference between Dish 1000 and superdish?
A superdish will have 2 dish pro LNBs and one stacked FSS lnb.Digital Rain said:What type lnbs are used for the superdish? Can't really seem to find much info on the system at all. what's the difference between Dish 1000 and superdish?
The larger pan is also needed to tighten the focus due to FSS having 2 degree separation instead of the 9 degrees used with BSS (DBS).Stargazer said:FSS is a lower powered satellite (medium power) therefore it requires a dish that is larger in size to pickup the signal.
You meant a DPP32 I believe.Stargazer said:The DishPro Plus (DPP) twin has something like a DPP-34 switch built inside
No you can't. You use a DPP Separator. The DP Splitter is an entirely different device.Stargazer said:You can also use a DPP splitter to connect two dual tuner receivers to the Dish1000. ...
