yep. Each receiver reads different
some meters are good and some suck rocks. Thats why when folks ask what signal strength/quality someone is getting unless its the same receiver you cant really compare
Ice,
Absolutely correct!
The receiver model and sometimes the firmware changes this considerably.
Then you have variations in the dish brand, model, size. The LNBF used, and the location. Then you have to be speaking of the same satellite and same TP to boot! And even switches and cables will affect the results.
There are just so many variables to consider when a discussion regarding these issues comes up. Whether we are talking about the signal level representation on the screen or what dish model or size is required...... ad infinitum.
So many folks do not realize that there are this many variables involved.
The receiver displays what it does, based upon the signal it senses at its input terminal. If the receiver is happy with the signal (displays a good picture and sound) while its meter reads 24% or 96% is immaterial. As long as it is happy, you are happy. You just have to get accustomed to the receiver that you own to become familiar with its own particular scaling.
Iceberg mentioned that the dropout % for the Coolsat was roughly 63% and that is what I have detected as well. That is for LINEAR satellite signals. I noticed that it is different for circular signals, so there is another twist (it is about 66-67%, if I recall correctly).
Basically, there is nothing incorrect with either the meter or the receiver, there simply isn't an officially adopted standard to make them all read the same.
It is kind of fun to compare, though. My Super Buddy has several options to read S/N ratio, S/C ratio and IRD %. When I select IRD %, it reads very close to what my Coolsat 5K meter reads. I like that, but the result that these match is pure luck and not much else, I think.
RADAR
