I've moved from the US to Canada and I cancelled my subscription for Dish Network and bought a 6100 to replace my 811 (same thing only enabled for expressvu) So I have a Dishpro LNB (not the quad) and a dishpro compatible receiver (the 6100) and am using one of the inputs from the Dishpro LNB into the 6100. I readjusted the angles and skew and am getting 100% on 91. (FYI - I also have a totally seperate installation already running ExpressVu.)
The problem is, that I can't get any furthur. If I do a check switch, which I read somewhere "you're not supposed to do", it comes up as showing 91 and x with all the rest x's. Of course I did a check switch because there were really no other options. If I switch to test the strength of 82 it says wrong satellite, but 100% strength. After I run a check switch, by the way, its says all of a sudden that it can see 82 but when I'm on the 91 menu selection, it obviously says this is the wrong sat. I can fix the check switch problem, by removing the sat cable from the receiver and running check switch again, and I'm back to showing 91 good.
The only other menu selection, which I've tried every which way, is to choose cancel, select yes from the dialog box asking me if I have a locked signal. It attempts to download the software for about a minute, no blue bar progress activity occurs, the screen goes black and it appears my receiver is resetting. Then once again the satellite signal meter screen pops up again and I'm back where I started.
So here are the questions?
1) How do I get to the program guide to ascertain whether anything is working out of this endless loop.
2) If I can't do a "check switch" on a Dishpro, how can I get it to start to recognize 82?
3) Is the system lying to me after I do a "check switch" in this case? Remember that it switched to saying it could see 82 instead of 91 after a check switch.
One thought is to use my other installation (I had two dishes on the side of my house, one with coax direct wired into the location I'm now trying to fix) which is running expressvu already and get the receiver through the download problem. Would this do any good?
Thanks in Advance
Thanks in Advance
