I have a round 18" dish. I have a cable directly from each LNB to each of two active receivers. No multiswitch. I also have a spare (3rd) receiver. One receiver gets all 101 SAT transponders perfectly (95+ on all necessary transponders.) The other reciever cannot get ANY even transponders. So I replaced it with the spare reciver on the same LNB, and the spare also cannot get even transponders. So I assumed I have a bad LNB. To confirm, I switched the good receiver onto the cable of what I thought was the bad LNB, and it CAN get all transponders. The other two receivers STILL cannot get the even transponders - even when on the other LNB. Can I possibly have two bad receivers with exactly the same symptom - not being able to get even transponders? Or is there some other expllanation. The problem travels with the receivers - regardless of what LNB they are on. I also tried disconnecting the good one and letting the bad ones power up first to see if they could "capture" the even transponders - not that I thougtht it should - but what the heck - but the working receiver, regardless of what LNB it is on- still gets all transponders and the other one doesn't. My next test is to put both bad receivers on - one on each LNB to see what happens. I am stumped. btw, I bought both non-working receivers on ebay - could they both be bad - they were cheap, but the new cards were 20 bucks each!
