0% Signal Strength on 5800?? (4700 works...)
Like the title says, I have a used 5800 which has been properly "activated" by Bell (by phone only so far), but when connected to a known, working dish, I get ZERO signal strength!
All menus on the 5800 seem to work OK, you can walk through the set-up, defaults, and everything else.
It is NOT a cabling/LNB issue as TWO 4700's running off the same LNB are working 100%. I simply disconnect the 4700, connect the 5800, and zero signal in the aiming menu!
The sat connector on the back of the 5800 reads 13V-18V. (seems a tad variable)
Ideas?
Ideas?
