Hi all,
I currently have a Stealthtenna with amplifier. From the Stealthtenna, I have RG6 run to a ground block outside that splits the signal in two. One side of the split signal goes to the V* receiver via the injector. The other goes to the bedroom TV with no injector. I want to add an injector for the bedroom TV also and would like to know where I can purchase an injector similar to the one I am currently using for the V* receiver. Does anyone know if adding a second injector will cause any problems with the amplifier located inside the Stealthtenna? I would appreciate any help with this.
Thanks, Tony.
Thanks, Tony.
