Hello, I have started becoming interested in FTA. I am currently into ham radio and it seems as if this is somewhat down the same alley, more experimental and as a hobby than anything else. I would be interested, however, in using the system as entertainment.
I do have a few questions. I live in a single story duplex sorta out in the country, I have a very clear view of the western sky in my backyard. I would like to keep the dish low to the ground if possible so that my landlord will not complain. It seems to me that as a non-ethnic person, Galaxy 10R would be the bird of most intrest to me. Where is this bird in relation to me, I know the degree measurement, but I am a total NOOB so if someone could explain to me how to figure out where the sats are? I want to mount a low profile outdoor VHF/UHF antenna as well for HDTV and locals reception, and i want to run this into the house and use my internal wiring(RG58) to distribute the signals. I have 3 OTA recievers. If i combine the sat. signal with the OTA signal outside, would this mess with either my OTA or FTA recievers? Also, I want to keep this setup pretty low cost to start off, I know I can get a reciever real cheap, so what is the cheapest I can get a dish, LNB, and switch. Also, I know that satellite uses some other type of cable like RG59, but can I use my existing RG58? this would save me so much hassle. If there is anything else I need to know being new at this please let me know. I really need to keep this low cost to start, so i don't need a motor or anything.
		 Just read a couple of more points in your last post, and wanted to add that G-18 (formerly G-10R) is, in my opinion, by far the best satellite up there for full time, English-language programming.  There are many local channels from around the country uplinked by Equity Broadcasting.  Their RTN (Retro TV Network) is like TVLand on cable, showing classic TV programming.  To answer your other question about combining your OTA signal onto the satellite cable, this can be done with diplexers if your cable run isn't too long (diplexers introduce signal loss, and two are needed--one to combine the signal outside, and one to split the OTA from the satellite signal inside).
