No. It "looks" like you are aimed at the west coast. Need better Pics.Does it look like its aimed correctly for 97w
C or Ku? Dish looks way too small for C Band.Got the dish mounted and can get 67% signal but no quality
i will try another day for better pics that was the best i could get today
Looking to attached a ku lnb tomorrow night or next week and aim with that then decide if I want to go c band on the dish or not it to hot this time a year in Texas to do much out side at 1:30 in the afternoon when the suns at approximately 97w
got the dish aimed today the elevation was to low and some how the dish was twisting on the motor shaft
If the dish or post is twisting when you put the dish on the post, you have a BIG problem. Nothing is going to stay locked if either is moving when you don't want it to. If the motor shaft is not locking down tight on the dish then you may need to shim the motor shaft inside the dish mount with a short piece of plastic pipe?
I had to shim one of my Channel Master dishes to be able to mate it with a STAB120. Works great.
I think the whole motor brackets out of wack I can adjust the dish by moving the dish left or right a little and the motor mount that's attached to the pole moves to
