I've recently purchased a HDTV and I'm using StarChoice HDef channels for the first time. Also, I'm located where reception is limited. Over the years I've had no trouble receiving the reg channels but now, with Hdef, I'm having some problems. If I "fine tune" the dish I can receive all the chans reasonably well at night but during the day some work and some don't. When I look at options 6-4-7 the db varies from around 2.4(not working) to as much as 3.2(works fine).
Okay, so here are my questions.
I was talking to someone today who mounted a e60 lnb on a e75 dish and claims it works fine. I got me thinking about trying a e75 lnb on a round 100cm dish. Would this likely work or help my signal strength?
Also, I recall having a higher signal strength when I was using a stacked lnb. If I switched back to stacked from quad would it likely help?
Now here's a really out in left field question. Has anyone tried adding something additional to the e75 dish that might give it more surface area and possibly a better signal?
Regards,
Regards,
