Does anyone know if a SC receiver will work with a Dish Network "Superdish" (with a linear lnbf) south of the boarder? I am not sure of the size of the superdish, but I know it is much bigger than a standard 18" dish.
depends on where you are in relation to the border. If you are in a state that borders Canada, then yes I would say it would work fine. But if you are closer to the "other" border I would say its too small. I've tried the smaller dishes for them (32x20) and they work pretty good in MN but a good rain will knock it out. I have a 30" dish aimed at F1 (main satellite)
Also the LNB is stacked so when you set up the programming via SC or a broker you would need to tell them its a stacked system...otherwise you wont get all the channels
