StarChoice 75e Dish
jself1982
1,272
South Carolina
Got an extra one the last time I made an order with KuSat, can I use this dish and the StarChoice LNB to make as a fixed dish for FTA?
Can I use it for 2 locations (i.e. AMC 6/SBS 6)?
Can I use the LNB on there already?
How do I connect it to my Disecq switch, with 1 or 2 cables from the LNB?
yes you can. Done it numberous times
the LNB's are 3.8 degrees apart
yes you can
since it has a 22k built in to it, if you aim at just one satellite, use the Sat B one (which has the 22k built in). Its at the focal point and not offset
You would only need one line since the 22k is built in
As for the 2 satellites, yes it can be done but if the offset (ie: 107.3) LNB might have issues with a weaker signal.
Lots of interesting combinations can be accomplished with 4 degree spacing. I've been looking into this recently myself, might get something going soon. One that I'm particularly eyeing (other than the 97/101 combo) is 89/93 (for feeds)...
89/93 will work but the only drawback is since the LNB's aren't exactly 4 degrees, some of the weaker signals may not come in
Radio shows
Can't program Coolsat 6000 Premium
