StarBand Echo*9 121 & Bjirdog Ultra
kodiak_ak
16
Kodiak, Alaska
I am trying to lineup a 1.2m Starband dish to orbital slot 121. My Birdog Ultra does not have the file, wondering if anyone has ran into this issue. I downloaded the latest "Specific" list from Birdog.TV site, but the 121 is missing.
If you are using birdog.tv -> click on the News and Downloads-> click on configure -> from there you will see two boxes. The one on the left is the available satellites that can be loaded. You will find the 121 starband satellite there, highlight it and click the > arrow to move it over. Then download and upload to your birdog and you will be all set.
If I understand Birdog, the Ultra uses a different data set. If you line it up using the Dishnet 121 vertical transponder, you should be close enough to finish peaking with the Skymanage screen.
Good Luck
I found the file on the Birdog Ultra download page (option 3 create your own list). Also, was able to hookup a Dish receiver to the Starband
LNB, set to point dish and lock to the 121 sat to verify.
EchoStar XVII Successfully Positioned in Orbital Slot
Comcast/xfinity question
