STAR CHOICE DISH
What type lnb? Size Dish? If it has dual lnb (pick up sats 4 degrees apart) T5 97 (AMC 19) and W4 101 (AMC 4) would pick up some international, religious channels.
The LNB is linear on the Starchoie/Shaw dishes so it would work for FTA. But the size is important. There are 2 models
60e (32x20 I think)
75e (37x27)
The 75e will work fine for FTA. The 60 will get the stronger transponders but it is kinda small. Also the LNB is 3.8 degrees apart so if you try 2 sats 4 degrees apart you may have a lower signal.
I took a 75e dish and did 97/101 a couple years ago. Worked really well
I've used the 60E to get the stronger transponders on 123 (back when equity was on that bird). I've also used it to get 97W with success. This is all from Victoria BC.
Way to tell where dish is currently pointed?
FTA RECEIVER AND OUTDOOR ANTENNA?
