I am in Hawaii with a 1.2 meter dish with 3LNB, an SMW, an H24 receiver and a standard def TV. The installer set up the system as if the dish were a Slim-3.
Problem: Channels that have both a Hidef and Standard def channel cannot be received. For example, MSNBC or National Geographic.
Workaround: If I do satellite setup on the H24 to ignore the Hidef satellite, (EG as a Round disk with 3LNB), I only get good signal readings for the 101 satellite, and I tune to the standard def versions of the MSNBC and National Geographic channels just fine (if I am the Slim-3 configuration, it tells me I have not ordered the channel). The problem with the round dish (101 only) configuration is that I do not receive my local channels.
My workaround is ok I suppose, and I will mount an antenna to get the local channels. However I was thinking that surely there are more than a few lunatics like me who don't care to put Hidef tvs in every room. Technically, the problem seems to be that even if I tell the box to only give me a 480i signal, the box still assumes that if I turn to channel 356, it should map the signal for hidef MSNBC from satellite 103 if it can see that. It seems perfectly reasonable to me that it should know that it should instead go to 101 to get the signal for standard def MSNBC. That's what it does when I put it in the round dish mode. Of course, I don't really care how it does it's business, but it seems to me that if there are at least some plausible explanations for how the box could do for me what I want, then perhaps some engineers had addressed the issue.
My question is: Is there some other way for me to get both my local channels and my standard def channels without my ugly workaround? Can anyone help, or should I just continue along with the off air antenna approach (BTW- I saw a connector on the SWM- is the H24 going to give me ok or do I have to get a digital tuner?)
Packages: Choice extra. I don't care about Hidef and don't pay for any Hidef other than those that come with the Choice package.
or should I say Aloha
