Southern satellite.
cappy29
352
6
Aliquippa,p.a
What is the southern most satellite that a dsr 922 can receive on c-band need to know for peaking my dish so far looks like W3.
Southern satellite
yes as far as I can tell this is it. I can not tune this sat in can you
You should be able to tune W3 unless you have something blocking the dish i need to find out if there is a satellite higher than that on cband for tuning purpose.
What is your Longitude? Look for the Satellite closest to it. W 3 is at 87.0w and it has an analog channel. If it's close to 79.0w, that's AMC 5 , there are some DCII channels on it, on the ku side. Sometimes you see analog channels on IA 8 (formerly T 4) @ 89.0w. There are some DCII channels on GB/G11/G18 @ 91.0w. Anything else in the neighborhood would be hit & miss for any analog? Good Luck!
correction, I had AMC 6, it's AMC 5.....
Southern satellite
What is your Longitude? Look for the Satellite closest to it. W 3 is at 87.0w and it has an analog channel. If it's close to 79.0w, that's AMC 6, there are some DCII channels on it, on the ku side. Sometimes you see analog channels on IA 8 (formerly T 4) @ 89.0w. There are some DCII channels on GB/G11/G18 @ 91.0w. Anything else in the neighborhood would be hit & miss for any analog? Good Luck!
Hi, i live in central pennslyvania and it looks like my longitude is 76 degrees,but i my ku-band lnb is bad so i need to use c-band for the tuning i tried messing with it before but couldn't find anything past W3 so as far as c-band goes it looks to be the highest for where i live, unless you know of one higher on c-band.
That's going to be tough, there are some DVB channels on AMC 6 @ 72.0w, but you'll need a DVB compliant receiver to get them. Looks like W 3 is your best option?
And, sorry I errored saying AMC 6 @ 79.0w in my previous post, that's AMC 5.
This TV?
