Sorting the Now Playing List on HR10-250
ctoddt
26
How can I get the Now Playing List to be sorted by title? My old non-HD Tivo was but my new HR10-250 is sorted by recording date. Thanks for any help.
Try this.
S <slow>
R <record>
T <thumbs up>
Do this while in now playing. Repeat to turn off.
Thanks. Got any more nuggets of widom like this?
Well in looking back at some previous notes I found these.
Use at your own risk!
30 second skip:
Select
Play
Select
Select
Clock on screen:
Select
Play
Select
9
Select
Episode info from the now playing list: (Must be in in Now Playing menu)
Thumbs Up
Thumos Down
Thumbs Up
7
8
Quick status bar removal:
Select
Play
Select
Pause
Select
Should be able to repeat command and turn these features off.
If your Tivo reboots you will lose codes and have to enter the codes again.
Good luck
Thumbs Up
Thumos Down
Thumbs Up
7
8
This does not work with the HR10-250. It works only with SD DirecTivos running 6.1 and above. :(
Sorting Tricks
Unless I am mistaken, you can press the INFO button while in the Now Playing List to choose from 3 sort options:
  • Newest (by record date)
  • Expiration (by expiration date)
  • Alphabetical (by program name) - and then this sorts within each like-named shows by most recent on top, I believe.
But maybe this feature is only activated AFTER you do that little "S0RT" code.
GAME MIX CHANNELS (701 AND 702) DISAPPEAR from GUIDE
SELECT NEW ORLEANS LIL's Now CONUS?
